Section View hatching not showing up!?
  • July 23, 2015
  • 2 replies
  • 2814 views
I've opened an assembly drawing in Creo 3.0 that was created in a previous version (Creo 2.0, I believe). None of my section views are showing up - views are there, they just aren't sectioned and don't contain any hatching. I've tried re-creating them to no avail. Any ideas?!
Thank you,
Brandon
You might have to share to file to what's up.
Also let us know if it is an academic version or commercial version file.
2-Explorer
July 31, 2015
Parts have solid geometry? (import geometry sometimes does not solidify, e.g. when there are holes in the surfaces)
Accuracy issue or geom checks? If you try to recreate and x-sections fail, there should be messages in the help line
