Segmented lines do not always extrude into segmented solids
I have a model I am working on. It is a polygon that I have extruded to have a thickness. This polygon has several sides where the straight line is segmented. This is important for later use in an assembly. 95% of the time this works fine and once extruded these lines maintain their segmentation. But every once in awhile, it merges the line. Oddly, when assembling, the extra vertexes are there, but the surface is continuous. I need this to stay segmented for later use. Any thoughts what is going on here?
