sheet metal half-shear button
Hi ... CREO4 user ..... trying to create a half shear button in sheetmetal part ... what is easiest/best way?
pausobAnswer
In the sheetmetal, use sketched form, change type to "piercing" instead of "punched" (2nd icon in the ribbon).
Then just sketch a circle...
BTW ... I tried to do a "sketched form punch" .... it made the small half-punched hole in the front surface, but creates a larger (added sheetmetal thickness) plug diameter on the back surface.    Hole diameter in front and plug diameter in back should be the same on a half shear button
Not sure what you mean by a half-sheer button, but how do you punch material and get the same diameter on both sides of your sheet?  The material has to be deformed someplace and I would expect the back side to be larger than the punch by the material thickness.
A half-shear button is a common sheet metal practice used for accurately locating parts prior to spot welding   ….. it basically punches a hole at half-depth on the front surface while creating a plug, of same diameter, at half depth out from the backside surface.
I’ve been able in the past to create this on solidworks sheet metal parts with just a two step process …. 1) create a hole at half depth on the front  2) create an extrusion out the back   ……………. But I can’t seem to do it in CREO
pausob19-TanzaniteAnswer
Perfect …. thank you very much !!
