Sheet Metal Rounds and Deformations - It Should Work
Good afternoon everyone,
I am working on a sheet metal part that is essentially a5" by 6" rectangle with 1" flanges on each of the edges all oriented in the same direction. We will be getting a tool to blank the flat pattern of this part. As such, the tool will be cut with a wireEDM and requires rounds on all of the corners at least as large as the wire.
I created the formed part, flattened it out and added rounds toall of the corners. I then made the rounds a deformable area so that there would be no issues bending the part back. Or so I thought. The rounds on the outside edges were okay, as they do not directly affect the formation of the part. However, the four inner corners with rounds caused the part to fail.
Is there a trick that I can use to get around this? (Pun not intended) Increasing the spacing between the formed edges of the flanges to give room for the round is likely not an option.
Thanks in advance!
