Shell Analysis
  • May 7, 2010
  • 657 views
Good morning all,
I am working on an a-surface for a client, (Can't share it. sorry) and I am testing the "shellability" of the model and I am getting the imfamous:
"Highlighted surfaces are too curved to offset by specified value."
Here is my question:
Is there an analaysis tool or a way to pinpoint the trouble spot in the highlighted surface?
I tried an offset surface analysis, and it showed that it would offset with no problems. (Even though a surface offset could not be performed.)
Doing a shaded curvature analysis, I was able to find the trouble spot. (Doing a maximum plot)
Coupling this with cutting away sections of the model and then shelling helped to find the issue.
Nate
