Short edges with threads
  • November 22, 2017
  • 1443 views
When modeling threads with the helical sweep, I get "short edge errors" when I run Model Check Regenerate. Is there a way to fix this? Thanks.
Mahesh_Sharma
22-Sapphire I
November 23, 2017
Short edge error in ModelCHECK report is an indication that part has edges shorter then specified limit..
You can disable that check by changing the E to N in respective check file. OR change the value of possible short edge in respective constant file.
