Show Datum Plane in Drawing View?
  • October 3, 2013
  • 6 replies
  • 15477 views
I can't seem to find a way to show a datum plane in my drawing view. I would like to show the plane and make dimensions to it. I called support about this, but they said it was impossible to show the datum plane, except for when the datum plane view was turned on. I want to select the datum planes I want to show, similar to how you would show a hole axis by clicking on "show model annotations" and selecting the axis you want to show. I can't believe that this isn't possible, it seems like a very simple thing. Can anyone help?
Best answer by Inoram
Is this what you want? Just show planes from the graphic toolbar, right click the plane and hit Properties and change the "A" (or whatever) to the "-A-" .
Look at GD&T. I can't look at the moment, I am into something. But I will look in a bit.
You might need to investigate the use of the "Set Datum Tag" Annotation Feature. Alternatively, you can right click on the datum plane and select "Set Datum Tag Annotation" display option.
Rocks11-VisitorAuthor
Scott, I can't seem to find a "set datum tag" option. I tried right clicking the datum in the model and in the drawing and neither of them gave me that option. I also don't see it under Annotate. Can you tell me exactly where it is? Thanks!
Inoram14-AlexandriteAnswer
Finally! Yes Matt that is what I needed! Scott, thank you for the information, I did want it to be a "proper" datum plane I just didn't know how to do it. Thank you!
