Showing datum axes in a drawing after they have been erased.
  • September 25, 2013
  • 4 replies
  • 3971 views
I'm having a problem in a drawing that I haven't been able to figure out...
There were axes in a view that I didn't want in there, so I did: right-click>erase on those that I didn't want. Later I decided I needed one back so I tried: Show Model Annotations > Model Datums > All. When I try this the axes I erased do not appear again...
Is there an option I can change or a layer I need to turn on or anything short of making new axes in the model to resovle this issue?
I appreciate your input
Best answer by TomD.inPDX
Use the drawing tree and activate the Annotation tab in the ribbon. The erased objects are now selectable in tree somewhere, most likely under a view heading. RMB will let you unerase.
Antonius,
Thank you that is exactly what I was trying to do but I didn't know how!
Thanks again
Dale_Rosema
Just becareful and remember the different between delete and erase:
Delete - gone
Erase - hidden
