Shtml accuracy and thickness
  • May 1, 2012
  • 3 replies
  • 1009 views
Good morning,
I am migrating some sheetmetal parts from R2001 to WF4/5/Creo1 (not sure
where we'll stop... J) and am getting the following "error' messages.
Correct range for Thicken ( id 462 ) is [0.0202 - 1000000.0000] instead of
current [0.0000 - 1000000.0000].
Change the model accuracy or modify thickness value for the feature to avoid
bad geometry creation.
These parts were/are happy in R2001 at default Relative Accuracy of 0.0012,
but are complaining as we migrate. I have changed the accuracy to 0.0002
already which Creo1 seems happy about, but WF4 is still issuing the error.
The baffling aspect to me is, this part has a thickness of 0.035" which is
greater than the minimum in the complaint. Also, what does it mean,
"...instead of current [0.0000 - 1000000.0000]." Where does it get this
"current" thickness?
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
20-Turquoise
May 1, 2012
On 05/01/12 08:20, Gavin B. Rumble, PE wrote:
> Good morning,
> I am migrating some sheetmetal parts from R2001 to WF4/5/Creo1 (not sure where we'll stop... J)
> /Correct range for Thicken ( id 462 ) is [0.0202 - 1000000.0000] instead of current [0.0000 -
> 1000000.0000]. /
> /Change the model accuracy or modify thickness value for the feature to avoid bad geometry creation./
> These parts were/are happy in R2001 at default Relative Accuracy of 0.0012, but are complaining as
> we migrate. I have changed the accuracy to 0.0002 already which Creo1 seems happy about, but WF4
> is still issuing the error. The baffling aspect to me is, this part has a thickness of 0.035"
> which is greater than the minimum in the complaint. Also, what does it mean, ".../instead of
> _current_ [0.0000 - 1000000.0000]." /Where does it get this "current" thickness?
> Thanks in advance,
> Gavin B. Rumble, PE
> Solid Engineering
> 336-224-2312
We had a few older sheetmetal parts that also gave this error when opening in WF5. PTC fixed these
parts and sent them back to us:
See case solution: CS23265
Based on the SPR listed, you have to send the parts to PTC to be
repaired?
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
20-Turquoise
May 1, 2012
On 05/01/12 09:55, Chris Gosnell wrote:
> Based on the SPR listed, you have to send the parts to PTC to be repaired?
Yep. That is what we had to do.
> FPD Company
> McMurray, PA 15317
> PH:724.941-5540
> FX:724.941.8322
> www.fpdcompany.com
> _______________________________________________________________________________
> Computers are like Old Testament gods; lots of rules and no mercy.
> /--JOSEPH CAMPBELL///
> *From:*Randy Jones [
> 1000000.0000]. /
> Thanks in advance,
> Gavin B. Rumble, PE
> Solid Engineering
> 336-224-2312
> Phone: 785-823-3276
> Fax: 785-667-2695
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
