Simplified Rep Selection Maximum 14000
So I am trying to create a simplified rep using the zone selection feature in Creo 2. Zone creation works fine, but when I try to use the zone to create a new simplified rep I encounter this selection issue. The warning I get is " Selection reaches its limitation 14000; the selections beyond this limitation have been ignored".
This is irritating. Is there any way I can change this setting to increase the selection buffer size? Also if anyone has encountered this in the past I am curious as to how you worked around it.
-Andy
