Simplifying a screw to modelization
  • September 17, 2015
  • 894 views
I have a "doble machined conical screw" model (originaly IGES format), and wish to simplify to using in a complex assembly and analysis.
(1) How can I eliminate all the teeth in one side of the screw? OR
(2) How can I fill all the teeth in one side of the screw?
THANKS
I think the solution should be a simplified representation of the part.
Create one or several quilts (merge not forget). This should be like a shell around the area of the part are.
Don't Forget the Option "Capped Ends"
Then create a simplified representation.
using the following Options:
- Work Region
- Use Quilt
- Solid
and "Fills volume delimited by quilt with solid material"
auf deutsch wäre es sicher einfacher zu erklären gewesen! Grüße nach Karlsruhe
