Single drawing with RSD as it was in diagram using overlay
  • May 9, 2012
  • 602 views
Currently we use pro Diagram to create a schematic and table of
connectivity. Then we overlay both in the cable drawing.
A question that I cannot figure out so far...
How do you overlay the RSD schematic into pro/e? Basically that is our
process so if I have to take a desktop jpeg and crop it, I will have to do
that.
Alfonso,
Try exporting to .dxf or .dwg from RSD then insert shared data from file on the drawing. It only comes through as draft entities and text though.
jef
