skeleton model and colors of the parts
  • July 18, 2007
  • 1445 views
Hello all, I would like to solve this problem I have: I have made skeleton model using surfaces which I am publishing to the part. On the part level I have solids made by solidifying my published surfaces (also quilts when needed). Why part surfaces gets color of the skeleton? When I clear colors of all surfaces in the part I get colors of the solid as I wont. When I change something in the skeleton then I get again color of the skeleton... What should I do to avoid this? Thank you for help.
Hi After publishing to the part, u r using published surfaces directly for solidifying, dont use published surfaces for solidifying, again do "COPY -> PASTE then go for solidify by using new surfaces. i think it will work Venu
huuska1-VisitorAuthor
Hello Venu, thank you for your advice. I thought it can be done by some config option but I have not found any. Regards Dalibor
