sketch
  • June 4, 2015
  • 833 views
How to analysis the sketch in creo? IF want to find  how many number of weak dimensions and strong dimensions?
I just uploaded one gold ball model, in that they did axis pattern but in that if u do axis pattern instances will come in the air only. Just make me to understand the pattern pleas
To analyze a sketch for weak or strong dimensions just hover the curser over a dimension and it will show weak or strong. Select the dimension and right click and you can change it to strong or lock or unlock. Not about to explain the golf ball pattern.
