sketcher mode, equal dimensions
  • July 27, 2012
  • 11 replies
  • 8796 views
wf4
In sketcher mode, is there a way to make several dimensions of equal value? If you look at the attached example, is there a way to make one 1.5 dimension equal/dependent on the other 1.5 dimension?
Hi DL,
I saw the other WF5 answer and I did not know that trick.
I have used the other construction line method (still do in WF5) and was
typing about that as I did not initially see the other very good answers.
However I can add that you can go further with those construction lines and
use them to control a sort of pattern in a sketch. Always with the proviso
that you want to be careful over how complex you make a sketch. At least
with this complexity though you can see exactly how something is
constrained.
*Brent Drysdale*
*Senior Design Engineer*
Tait Communications
