Sketcher Symmetry
  • January 8, 2010
  • 4015 views
We have just had wildfire 4 installed. With wildfire 2, in sketcher, I was able to sketch my shape roughly either side of a datum plane and then use a centerline to 'snap' the shape to be symmetrical. This no longer seems to work with the new install. Does anyone know how to get it back ? I have intent manager switched on, and I realise I can make the shape symmetrical using constraints, but the old way was so much quicker. Any ideas ?
I believe it still works. What you may need to do is sketch the centerline (horizontal, vertical or both) first, right on the sketch references (presumably datum planes). Then if you sketch, for example, a rectangle, it should snap to symmetrical on those centerlines.
Thanks Chris, that works to a certain degree but if I put 2 circles in the rectangle either side of the datum I still can't get these symetrical using cetrelines.
you could use mirror in sketcher Reinhard
