Slot for a cam
- October 10, 2017
- 1 reply
- 2196 views
Hi all,
my goal is obtaining the motion combination between two axis
1) a cam (motion in)
2) a disc (motion out)
So we have a globoidal cam. I move the disc with a slot connection; the two bodies are constrained with two pins.
The problem is that I have 1 redundance.
I also tried inserting a thirrd body (a part .prt wothout solid mass, but only with points and axis, like a skeleton) but I failed.
How can I erase that redundance?
I made some calculus to verify if the dynamic entities were wrong with the redundance: I applied an acceleration of 1 deg/s to the cam and I verified if the total load at the motor, due only to the inertia of the disc, was correct. It was (I attach also the Mathcad Prime 4 sheet; sorry but it is in Italian).
So I don't know if that redundance is a problem or not...
PS: the assembly is made with WF5, but I've also Creo 3.
