Slow model lines reaction (ptc wildfire 5.0)
  • December 22, 2012
  • 5 replies
  • 1854 views
I got a new pc setup and i've got some problems with ptc wildfire 5.0. On my computer everything is working fine.
I installed ptc on my new pc and everything went ok. When i open a part en go over the model the model lines (blue lines) show up but they react very slow en go away even slower. The lines "runs" thru the whole model before disapering. Everything else is working fine. (Im able to do analysis in pro mechanica ect...)
Setup:
Intel i5 3570k
Asus amd 7950
Windows 8
(sorry for the bad english)
In Menu option go to edit and go to select the & untick the highlighting preferance... your problem will get solved
Thx for the reply. The problem is solved now. Do you know the reason why it reacts so slow?
Dale_Rosema
Go ahead and mark the correct answer so if someone search and find this thread, they will know that you found the answer and that they will too.
