SMOOTH_SHARP_CORNERS
So I want to know if others use this option or ignore it. I have used this option for 3 axis milling Roughing and Re-Roughing cycles for awhile now and have noticed some issues with remaining material. By that I mean that when a Re-roughing cycle is calculated it seems to not account for the material that remains when the roughing pass is modified by this option. This issue has lead to broken and badley worn tools in my shop. I have used mainly MAX_RADIUS and (SMOOTH_RADIUS = .05). What has been your experiance with this option?
