Solution - Selecting entire curve instead of part of curve
Thanks for all of the help!
Several suggestions made it work.
1.) Doing the right click and querrying through to get the whole arc...(I tried this, but obviously was doing it wrong)
2.) Using the sketched curve and extruding a surface and picking 2 datum planes and using the smart filter and selecting the extruded surface/quilt. (I had tried this, but didn't change the smart filter and was having the same issues)
3.) I also found by selecting the curve and datum plane in the model tree and then creating a point it'd throw it right in using the whole curve.
Thanks for the help/suggestions! I knew there had to be a way.
Ted Otto
Ted Otto
