Splices in bundles
  • July 15, 2014
  • 2 replies
  • 2776 views
I am rather new to Creo Parametric 2.0 (always used other programs).
I add the splice using the Insert Component button in the Cabling ribbon.
I am having trouble with splices and adding them in bundles.
I end the bundle at the splice and start a new one, but one of the sides always comes up with an error that the cable diverges from the bundle and can't add them.
The red one is the bundle above the splice. As you can see the bundle under the splice is fine.
Is there a way for me to forcefully add the wires to bundle?
Thank you in advance,
Ron
Best answer by ptc-6294531
Thank you for your response, but it gave me the exact same result.
Edit:
This is what I need to do to fix it:
-Place the splice with "Insert component" to get the right direction, save the location, delete the component and add it again with "Assemble".
-Then I need to adjust the parameters of the splice (this is due to our script)
-After that I need to reroute the network to connect "the right way" to the splice.
-Last I need to route all the wires manually into the correct side of the splice. (VERY VERY time consuming)
This method take me about 2-3 times longer but at least my wires aren't sticking out.
Delete some portion of wires (from splice to next location) where you face above issue. Reroute them again and pack the wires in bundle...
ptc-62945311-VisitorAuthorAnswer
Edit:
