8-Gravel
April 8, 2019
spline - read points from file
  • April 8, 2019
  • 0 replies
  • 865 views
Is there any way how to load spline points from file according to parameter?
For example I have files with points:
points_1.pts
points_2.pts
and I want to load file points_1 when I set some parameter to 1 or load points_2 if parameter is 2... and so on.
The reason for this is that I use ansys workbench with creo and need to change geometry from workbench according to parameter value. The geometry is precalculated in the files.
Thanks for help
best regards,
Michal
