spring modelling
Hello all,
My Pro/E knowledge is a bit rusty, I stopped using it regularly in
v2001. Now i'm trying to model a spring in WF4. And I need help.
What i did was model a datum curve, from equation, using cylindrical
coordinates. Nice and easy.
Then I modelled the ends of the spring as sketched curves. They ended
up showing as "sketch" in the model tree, which I think is weird, but
okay, feature info says they are curves, so it should be good.
Then I made a composite curve, approximate. My goodness, what a
counter-intuitive bunch of steps you have to follow to get that done. I
would never have found how to do that without Googling. But okay, on
with the work.
Finally I wanted to make a Sweep over the curve. Didn't work. Invalid
trajectory.
Okay maybe i did something wrong, but let's see if I can at least get
the spirally bit swept? It turns out, I can't. Pro/E won't create a
sweep on the datum curve from equation (cylindrical coordinates). And I
have no clue why?
Someone please tell me that it is still possible to model a simple
spiral spring with both ends having some smaller-radius going into
straight ends, within 10 minutes? It used to be a piece of cake. Now it
seems to be very complex. Is it just me, or is it the software?
Best regards,
Patrick Asselman
with the work.
trajectory.
have no clue why?
Best regards,
Patrick Asselman
