Square butt weld of pipes
  • March 14, 2017
  • 2895 views
I have couple of hundred pipes in an assembly that should be welded together using square butt weld. There seems to be a way of adding a "pattern", but this doesn't seem to exist in Creo 4. I can't find the option.
Further more, all welds are of the same type, so all I want to show is the weld number. How do I remove all the other parameters that are shown?
bbrejcha
not sure how you would pattern a butt weld in an assembly because the weld should be pattern-able.  Works great with spot welds because the weld is linked only to a point that is pattern-able.
Consider uploading your assembly or maybe a screen shot.
Bart Brejcha
Design-engine.com
Bart Brejecha designengine.com
