Step File Import Issues - Model is half covered by a block
  • February 21, 2013
  • 5 replies
  • 2039 views
Hello, I am trying to export my Pro-E file as a Step file. I can export my model as STP just fine but when i import the file, there is my model, and half of it covered by a triangular block.
I can simply remove this block but is there any way i can export the file so that this block is eliminiated to begin with?
Any comments/ suggestions would be great
thank you
Best answer by ptc-3448975
Tools
Options
Find
Type in intf and then the system will list all of the configuration file options that begin with intf. This is where you could choose the intf_out_blanked_entities and set its value to no.
Apply
For future reference.
This seemed to solve the issue.
Thank you for your support!
I've had this problem before. The save-as is exporting things that are hidden.
You might be able to use the "Customize Layers" status in the dialog to have it "exclude content" based on layers.
thank you for your response.
I followed your instructions into customize layers.
There are two options
ignore
or
skip
The default is set on ignore.
i tried with all the options on skip but no luck...
ptc-34489751-VisitorAuthorAnswer
Tools
Options
Find
Apply
