Strange Xsec colors
- July 11, 2014
- 3 replies
- 1730 views
Hey guys,
This has me stumped. I have an an extruded object. I took a cross section of it so I could inspect the insides. The appearance on the inside (light blue) is different from the outside (brushed steel).
I tried applying the appearance to both the intent surface and the part with no luck. This only happens when I take a cross section. If I extrude through the component, the internal colors show up just fine.
I should point out that the solid light blue that shows in the cross section is the same color as shown in the MODEL APPEARANCE EDITOR in the PROPERTIES box under COLOR.
Any tips to change the light blue back to brushed steel would be much appreciated. Clearly, I changed the defaults somehow.
