Stupid Noob Question of the day - Can I create predefined dimensions for bolts - screws - holes?
I'm in a bit of a quandry over the hole wizard. I've just started my 1st job as a designer and already I've got questions - go figure! When you click on the hole wizard you can choose the size of the tapped hole for a bolt or screw, but can you predefine the dimensions associated with that partiular hole size? Case and point, my company has a standard for 1/4-20 screws that follows this... Screw Dia: .250 Tap Dril: .201 Counter bore: .41 Dia & .26 deep or Counter sink: 82deg x .54 dia.
I'd like to go in and edit some predetermined parameters for the standard bolts & screws we use. Any help woud greatly be appreciated.
-john
