Style feature curve end points
Hi all
When you attach a style curve end point to another curve/edge it allows
you to set the distance from one end of the reference you attach it to.
However, it typically uses the "wrong" end to measure from, and I don't
see any way to switch which end it measures from. Is it possible to
select either end as the reference to measure from? Or does how you
select the reference curve make a difference?
WF4.0
Doug Barton
Senior Mechanical Designer
Parker Hannifin Electronic Controls
Electronic Controls Division
1305 Clarence Avenue
Winnipeg, MB R3T 1T4 Canada
direct 204 453 3339 x309
fax 204 452 7156
www.parker.com/ecd
"PLEASE NOTE: The preceding information may be confidential or
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
WF4.0
Doug Barton
fax 204 452 7156
www.parker.com/ecd
cooperation."
