Suggestion for Creo 4
  • August 11, 2014
  • 11 replies
  • 4729 views
I'd like to suggest an improvement for Creo 4.
Cross hatching in drawings, copy all button for hatching styles.
We currently can copy hatching styles from one view to another by selecting them both and then stepping through each component and pressing copy.
I'd like a copy all button, it may not give me exactly what I want but at least it would give me a head start.
First time I read that it's possible to copy hatching styles from one view to another. Might be a timesaver, thanks.
If it is just a matter of clicking into menu manager on "Next" and "Copy" buttons, then it can most propably be automated via a mapkey.
Guess I'll have to make one.
SamuelBrantner
maybe you should take a look at this:
https://www.youtube.com/watch?v=8rOiqHHU9Cw
Greetings Sam
i also recommend 3d sketch,multibody and improvement in fill surface
what improvement due you want in fill surface?
merge inheritance works similar to multibody..
projected sketch /3d will not be filled and many other option for closing boundaries which creo has as another extension in ISDX ...u can see solidworks surface functionality of filled surface u know the difference....
