summary - Export to DWG - ACAD14 - Wildfire5-M020 - "DWG file creation failed."
  • March 26, 2010
  • 3 replies
  • 1022 views
Summary:
Drawings previously created in WF3 and opened in WF5 containing BOM
balloons could not be saved as AutoCAD14, DWG file format.
Resolution:
Clean region, recreate BOM balloons and the save/export to AutoCAD14 goes
fine.
Hope it helps.
Luke
Luke Diventi <->
03/25/2010 12:59 PM
Please respond to
Luke Diventi <->
To
cc
Subject
[proecad] - Export to DWG - ACAD14 - Wildfire5-M020 - "DWG file creation
failed."
Hello Pro/Users,
Before placing a call with PTC support I want to see maybe I can get my
fix from this great forum.
Problem:
When Pro/E drawing is saved or exported as a DWG file in AutoCAD14 the
save operation does not succeed and an error message appears.
We noticed that this happens when the drawing contains BOM balloons.
Error Message:
Temporary solution:
We save in Autocad2000 and the export is successful.
Permanent fix (we really need the AutoCAD14 format since a lot of our
vendors are requiring it):
Any thoughts, fixes?
Thank you in advance!
AutoCad 14 was issued in 1997
how many more years till will every cad software program is not required to export in AutoCad 14 format
DiVenti1-VisitorAuthor
I know, I know, I'm having the same discussion without success over and
over...
I'm assuming this happens because small fabricators/manufacturers which
cannot afford an AutoCAD 2000/2007/2010 license...
So our standard save is Autocad14.
dave mcclinton <->
03/26/2010 03:07 PM
Please respond to
dave mcclinton <->
To
cc
Subject
[proecad] - RE: summary - Export to DWG - ACAD14 - Wildfire5-M020 - "DWG
As it happens, I just had an issue today where a machine shop needed a
file in DXF for autocad ver 12(!) for the conversational control on
their wire EDM machine.
Their complaint was that the 2D spline curve I sent them was coming in
as polylines. I explained that v12 DXF will always do this...
You may find this as well. Many machines with 'Windows' interfaces are
being used now. We have a machine that still uses NT!
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
