Summary - Helical surface using trajpar
  • April 9, 2010
  • 0 replies
  • 524 views
ORIGINAL QUESTION
I want to make an auger type surface and I cant remember how to set up the
relation for trajpar. I am trying to use sweep to get straight line
trajectory create a helical surface. Sketched section is straight line
with length and angle dimension. I set the relation to sd4=trajpar*360*5
so that the surface will twist 5 times around during the sweep trajectory.
However it does not work for me. I am going to search for the old files I
know where I have seen this but I thought the group would be quicker.
