SUMMARY Mk2 eDrawings for WF5?
  • May 22, 2010
  • 0 replies
  • 482 views
Hi Folks,
Just goes to show I should have read the rest of the exploder email on this.
To summarise.
- From Neal eDrawings 10.1.0.144 works with WF5 M010 (and presuamably
later) BUT
- There is a reply from Jeff saying
- We use WF5 M040 and eDrawings 2010 (10.1.0.144), and there is
definitely a problem. With previous versions of Wildfire and
eDrawings, we
had a mapkey that changed our Pro/E drawing files to a
black-on-white color
scheme. This gave us very easy to read eDrawings files that
resembled paper
drawings. With the later versions, however, if we try to create
black-on-white eDrawings files, we get "white or light gray geometry and
white dimensions on a white background" eDrawing files. This happens
regardless of the DXF export options and color schemes we've
tried in Pro/E.
There may be a combination of color settings and DXF export options that
will give us what we want, but we haven't found it yet. We
finally decided
to use the default Pro/E color schemes for our eDrawings drawing
files until
a fix is released.
The eDrawings part and assembly files work fine.
In a nutshell, if you don't want black-on-white eDrawings files, it
works fine.
- From Jean-Fredric saying
- 10.2.0.122 is not working with WF5 M040
- And from Michael saying 3D pdf that can be put out from WF4 and up
makes EDrawings obsolete. Will ahve to try this.
So for us it looks like we can use eDrawings for parts and assemblies which
is all we use it for.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
