Supports in spec driven piping
  • April 25, 2014
  • 4 replies
  • 1806 views
Does anybody know how to configure supports in spec driven piping for multiple pipe lines?
Do you mean a single fitting supporting multiple pipes at once or a fitting that is used by different specifications?
I have no idea for the former, while the latter is quite simple: just enter the support in the asfiles for each pipe spec. The same support can be used by multiple specs.
jsarkar1-VisitorAuthor
Your previous one, a single support containing letsay u bolts for multiple pipe lines.
2-Explorer
May 5, 2014
So in real life you use supports that can hold multiple pipelines.
And you want to model this in Spec Driven Piping, using the same instance of a support fitting for several pipe segments (from different pipelines), right?
Spec Driven Piping is not my specialty, but I can imagine that this is difficult to handle from the logic in the program...
