supressing an feature from an assembly
  • April 27, 2010
  • 647 views
I have written a code whose expected behaviour is to supress an particular feature from assembly.I am using "ProFeatureSuppress" ,all the aguments I am passing are correct but still its returning an "PRO_TK_GENERAL_ERROR" which means an supress operation failed.Could anybody let me know why this is failing & solution for this.
I am using WF 3.0.
Rahul
Rahul,
If you posted your code we may be able to help you further. It's
difficult to say what is going on without looking at your code.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
