Sweep by using multiple sketches (Chain Sweep)
  • April 29, 2015
  • 4 replies
  • 10071 views
Hi Friends,
I have a question regarding Sweep feature in Creo 2.0.
Earlier in Pro/E WF we have a feature like "Sweep" select trajectory "One by one" method and I was able to do sweep by selecting multiple sketches irrespective to direction of Sketches.
Have a look to the attached image
This is what I do in Pro/E WF.
But now I am trying to do the same in Creo 2.0 but I am not able to find the same method in Creo. Do we have the same option or any other method to do the same thing in Creo itself.
Guys please help.
Cheers !!!
Best answer by MartinHanak
Yogesh,
select constant section button in the dashboard AND when selecting trajectory references, press SHIFT key.
Martin Hanak
Yogesh,
Martin Hanak
ygupta1-VisitorAuthor
Thanks Martin,
It does work.....
Cheers !!
You can use "shift" to build edge chains within many features - selecting curves for boundary blends, draft hinges, trajectories, etc.
