System colors in WF5
- September 17, 2012
- 1 reply
- 1619 views
To elaborate, set the settings as you'd like, then save the syscol.scl
file (from the file menu within the System Colors dialog). Then you
need to add this to your config.pro:
system_colors_file c:\full\path\to\syscol.scl
That will make sure it loads automatically every time you start Pro/E.
Doug Schaefer
Doug Schaefer
