3-Newcomer
System‑Level Crash in Creo Parametric 13.4.0.0
Summary of the Issue
Creo Parametric 13.4.0.0 is causing a catastrophic failure of the Windows graphics subsystem across every machine tested, including:
  • University lab computers
  • Instructor workstations
  • Student laptops
  • My personal workstation
The failure is identical across all systems: initiating certain display operations causes a full backscreen event
Observed Behavior
Across all affected machines:
  • Entire display system blacks out
  • All monitors reset
  • No Creo traceback or crash log is generated
  • System becomes unresponsive for several seconds
  • Creo must be manually relaunched, unsaved work is lost.
Crashes occur seemingly at random. This issue is present on my personal computer, laptop, university computers, instructor computers, and other student’s personal machines.
Emeritus
Hi ​@JS_14622336,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Community Moderation Team
Michael_Bourque
Tell us what computers you’re using and what your graphic card is and that you’re not visiting a virtual machine.
Michael Bourque
3-Newcomer
I am unsure of the specs used in the University Computers that experienced this issue. My personal computer uses a Ryzen 7900xt + i5-13600 + 32gb RAM. No virtual machines were in use.
