Table>Create Balloons>By Record>
  • January 16, 2018
  • 2 replies
  • 1966 views
Using:
Table>Create Balloons>By Record> (select bulk item in BOM).
I get a balloon with qty. However, the qty is 1. We use A/R. It was established in the BOM relation and does report as such in the table. But not in the balloon.
Can that be changed from 1 to A/R. My bet is no.
WayneF
2-Explorer
January 16, 2018
You can create a custom balloon that reports any field that is in the BOM table.
http://support.ptc.com/help/creo/creo_pma/usascii/#page/detail%2FCreating_Customized_BOM_Balloons.html
wfalco16-PearlAuthor
Kinda figured I'd be headed to custom. Thanks! I will check this out.
