Table Pattern
  • November 30, 2012
  • 731 views
Hello All PTC Users,
I have a question in Pattern Tool. When we are using Table option in Pattern. in that part it work.
Now My question is that i want to export that Pattern Table into Other Pro-E File. So it is Possible or not.
and if Possible so what is the way to do that....
20-Turquoise
November 30, 2012
In Wildfire 5.0
1. open part with pattern table to export
2. Edit Definition of the pattern
3. select "Tables"
4. rmb over table of interest and select "Write"
5. this creates <tablename>.ptb.1 file in the current working directory
* You can edit/copy these tables with your favorite text editor
6. open part to import pattern table
7. Edit Definition of the pattern
8. select "Tables"
9. rmb over any table and select "Read"
10. open table file from step 4 and note you have now added another table
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
