The naming convention for Creo Apps
  • October 28, 2010
  • 6024 views
I cannot get over the name of the elements. I don't mind the Creo part. It is actually kind of cool knowing the latin ideas behind the word. I was also excited to see that it was a short 1 word name.
I cannot stand the "element/" portion. Many times I want to search the internet to find information on Pro/E. This is infinitely hard because there is the split in the name. You never know what exactly someone called it. Now, we are going to be stuck with an unnecissarily long name with the dredded '/' still in it.
In my oppinion they should have made the names: Creo Pro, Creo Direct and Creo View. Forget the element/ it has no value to the end user. All the other AnyRole Apps could follow the same format, Creo Manikin, Creo TAX, Creo Mech, Creo FEA, Creo Surface and so on.
PTC please rethink the name before the official change happens. Put your customers wants first. And please don't for the .0 on the name. That get so old. Just call it Creo 1
The elements part of the naming is suggesting that it does not have the full CREO functionality.
You only need to live with it for 1 year and then it's just CREO going forward.
If they called it CREO Pro, it would look as if they went backwards when they release just CREO. CREO Pro would have to be better than CREO right?
I am not worried about the temporary name. CREO elements/pro is just temporary and we could always truncate them in this way.....
CREO elements/pro = Cep
CREO elements/create = Cee
CREO elements/view = Cev
pwyndham1-VisitorAuthor
I did not know that they were temperary names. That's completely different. Did they say that in the meeting. I must have been thinking how much better my life is going to be if I don't have to worry about people creating parts in SW any more.
Paul - Creo Elements refers to the current shipping versions of Pro/ENGINEER, CoCreate and ProductView. When Creo is shipped, it will have new applications built completely on Creo and be compatible with the data from Elements. At this stage the Elements tag will drop and all apps will simply be Creo apps.
