the script language"COMP_FEAT_RELATION"
  • July 2, 2015
  • 1660 views
hello:
may i have a question about "COMP_FEAT_RELATION"
I study and look all tab files and find three places about "COMP_FEAT_RELATION"
FIRST: \afx\parts\equipment\bosch\schutzzaunsystemeinhaengewinkel_set.tab
SEARCH_COMP_OWNER_REF RAHMENTEIL CSYS ACS0 PLAZIERUNGSKOORDINATENSYSTEM
ASSEMBLE THIS_MEASURECOPY
WINKEL_MEASURE ANGLE1 ANGLE2
CSYS PLAZIERUNGSKOORDINATENSYSTEM REF_CSYS
COMP_FEAT_RELATION RAHMEN_H PLAZIERUNGSKOORDINATENSYSTEM DISTANCE2
COMP_FEAT_RELATION RAHMEN_B PLAZIERUNGSKOORDINATENSYSTEM DISTANCE1
END_ASSEMBLE
SECOND:\afx\parts\equipment\steel_construction_mm\beam_endcaps\endcap_rect.tab
ASSEMBLE THIS
CSYS PROFILE_END_CSYS CAP_CSYS
COMP_FEAT_RELATION W PROFILE_END B
COMP_FEAT_RELATION H PROFILE_END H
END_ASSEMBLE
THIRD:\afx\parts\equipment\steel_construction_mm\ladders\ladder_cage_1.tab
SEARCH_COMP_OWNER_REF LADDER_PART PLANE LADDER_PLANE ATTACH_PLANE
SEARCH_COMP_OWNER_REF LADDER_PART PLANE CAVE_TOP TOP_PLANE
SEARCH_COMP_OWNER_REF LADDER_PART PLANE A_XZ BOTTOM_PLANE
SEARCH_COMP_OWNER_REF LADDER_PART PLANE A_YZ CENTER_PLANE
H_MEASURE DISTANCE
ALIGN BOTTOM_PLANE A_XZ
ALIGN ATTACH_PLANE A_XY
ALIGN CENTER_PLANE A_YZ
COMP_FEAT_RELATION W ATTACH_PLANE W_OUT
END_ASSEMBLE
I don't understand this script language(COMP_FEAT_RELATION and SEARCH_COMP_OWNER_REF ) ,can you explain these for me?
for example:    SEARCH_MDL_REF Model Filter Name Variable
Model = "Model name" | THIS | THIS_# | ASSEMBLY
--> Model name = can be defined through USER_SELECT by entering the chosen variable
--> # = Component ID (Only in assemblies)
Filter = SURFACE | EDGE | PLANE | AXIS | POINT | CSYS | QUILT
NAME = "Feature name" (Name of the feature, e.g. DTM1)
who can help me!!
thanks!!!
SamuelBrantner
Hi 伟 曹‌,
here is the definition of the two commands:
Create Relations
The following command will create a component relation in the assembly, where the
component will be assembled into.
COMP_FEAT_RELATION DIM_COMPONENT REFERENCE_PART DIM_REFERENCE_PART
DIM_COMPONENT = Dimension of the model to assemble
REFERENCE_PART = Part to look in for an dimension. can be defined through USER_SELECT
DIM_REFERENCE_PART = Dimension of the reference part
Example:
Will create a component relation in the assembly.  In this case it will be W:20 =
B:6.
This means, that the dimension W of the component to assemble will be equal to B
of the component you selected (PROFILE_END).
Search in owner model
The following command is used, to search for a certain reference in the owner model
and store its information in a variable.
SEARCH_COMP_OWNER_REF Model Filter Name Variable
Example:
Searches in the owner model defined through LADDER_PART (e.g. Ladder.asm) for a plane called CAVE_TOP
and stores its result in the variable TOP_PLANE.
Greetings Sam
Greetings Sam
