There should be a function to display the values of a machining form element
  • November 5, 2014
  • 0 replies
  • 532 views
In Modeling it is only possible to obtain a display of the parameter values used to create a machining form element by using the command to change the values of the form element. If the object is locked then the lock must first be removed.
In 3D Access it is not possible to remove the lock and it is not possible to use the command to change the values of the form element. The only possibility I have been able to find to display the values used is the function "Generate Custom Feature Report". Unfortunately, this report is not suitable for use by an end user, and I have found no way to customize it.
It should be made possible (both in Modeling and in 3D Access) to obtain a display of the parameters set on a given machining form element that has the same look and feel as the display obtained when attempting to change the values of such a form element.
