Thinner lines when exporting or printing a drawing as pdf
Hello, whenever I export my drawing as a pdf or print it as a pdf the lines are all pretty thick. Acutally so thick that you cannot see any real detail. I would like to change that.
I read a lot about this tabe.pnt file, but i cannot find it anywhere.
Also i tried copying the following in my config.pro file:
pdf_use_pentable yes
use_8_plotter_pens yes
pen_table_file path_to_file
pen table file - example
pen 1 thickness 0.05 cm; color 0.0 0.0 0.0; drawing_color
pen 2 thickness 0.025 cm; color 0.0 0.0 0.0; letter_color
pen 3 pattern 0.5, 0.2 cm; thickness 0.025 cm; color 0.0 0.0 0.0; half_tone_color
pen 4 thickness 0.035 cm; color 0.0 0.0 0.0; edge_highlite_color
pen 7 thickness 0.015 cm; color 0.0 0.0 0.0; dimmed_color
This did also not work for me.
Could there be anything that I am doing wrong at the moment?
Greetings
Spedex
HidetakaAnswer
I think the problem is that your defined thickness for drawing_color is so thick.
I set the thickness 0.026 cm, and it works fine. (You can reduce thickness until it looks good)
Also, if you literally copy those lines to config file, I think it won't work:
You should create a .pnt file and define the thicknesses inside that file, not in config.pro.
For example, if you create customThickness.pnt and put it into folder  D:\Creo_Config
The following option should be set in config.pro
pen_table_file D:\Creo_Config\customThickness.pnt
The contents of customThickness.pnt is similar to your text, eg.
PTC has an support article on this, and I think the article is very helpful.
https://www.ptc.com/ja/support/article/CS124860?art_lang=en
tbraxton
If you open the pdf file in Acrobat reader or Acrobat and then press ctrl+5 it will reduce the line weight of visible lines. Try this and see if it resolves your issue.
Hidetaka1-VisitorAnswer
Spedex12-AmethystAuthor
Thank you all very much for your answers.
I created this table.pnt file and changed the value from 0.05 cm to eg 0.02 cm. It worked.
But I came across a new problem.
The central axes as well as the hatching is not effected by those changes:
I tried changing the values of the other pens, but also this did not help.
In explicit i tried changing the following values:
Does sombody have any idead how to fix that?
Greetings
Spedex
Greetings
Spedex
Axes ...
By default axes have brown color. In this case you have to add datum_color keyword to some pen.
Eg. pen 2 thickness 0.025 cm; color 0 0 0; letter_color; datum_color
X-hatching ...
What color is assigned to you x-hatching? In my case it is Letter (pen 2 in your pentable)
