"This view has been frozen because of illegal view instructions.": does anyone knows what it mean
  • July 31, 2017
  • 5 replies
  • 4975 views
i got this message from time to time and the geometry lines dissapear until the next action in the drawing (the dimensions and notes are still visible):
Does anyone knows what this means?
Nic.
2-Explorer
July 31, 2017
I have interpreted it to mean that some or all of the geometry references that oriented the view are missing. Someone picked a face or an axis as a way to control the view orientation and now that feature is missing; either suppressed or deleted. It's always best to use default datums as the primary choice, but sometimes that's not applicable, such as creating a view that is normal to a surface.
this being a projection view, you suppose that the message refers to the parent view, the main view? But the "invizible" geometry is on the projected onw, not the main view.
2-Explorer
August 1, 2017
It could be the feature that was used as the projection reference is no longer there. In looking at Google results, ways that some users get this is either by using insert mode which supresses a referenced feature or by converting a solid part to sheetmetal which may replace (replaced? some of the search results are over a decade old) most of the surfaces with new surface IDs.
I don't know for certain what Creo uses to determine orthographic projections, but I thought those were transforms of the original view matrix and should succeed unless the base view also has an error.
I would expect that the underlying process that any CAD system needs is to be given a vector that is normal to the screen/drawing as the primary orientation and then another vector that is projected on the screen to clock the view. If that second vector is zero length or non-existent, then that would generate an error. Since it's a calculation it's possible to have an error in making the calculation. In the case of non-orthogonal projections the second vector can be derived.
