Thread turning
  • May 20, 2012
  • 2 replies
  • 1290 views
Hi folks,
I admit I'm not much familiar with thread turning in Pro/NC. As we have a bunch of weird threads in our segment that most CAM systems can't deal with, so I never messed much with thread turning in Pro/NC...
However, I'm working on a new PP and I plan to have what Pro/NC can offer well deployed... but I'm not figuring out the thing with THREAD_FEED parameter and some other stuff...
In ISO cycles THREAD_FEED is the pitch (At least in the tape file) but in AI MACRO it's seems to behave different...
Can anybody help this poor guy to understand PTC's mess? I don't know why these guys love to complicate the simple...
I need to really understand how I can get the depth I want in the tape file, I mean: Let's suppose I have a O.D. thread Ø450 with a pitch of 5mm... I want the diameter at the bottom to be Ø440mm... but the "thing"decides that it should be Ø445.092 in the tape file...
THREAD_FEED is set to be 4mm
CLEAR_DIST is 5.0mm, that's why we get a X460. in the beginning...
INFEED_ANGLE in 30 degress...
PERCENT_DEPTH is 0.25 and NUMBER_CUTS 10
If I sketch a turn profile in the O.D., where can I inform the depth is 5mm (Or 10mm diametrically)? I noticed in General type I can do it, but THREAD_FEED still interfering in the result, and I still not sure about what CUT_FEED does as it is a mandatory parameter...
I'm definetely lost on this one... two possibilities here: is too simple and I'm a stupid or the inverse...
Any help is greatly appreciated,
Daniel Santos - CAM Support
GE Oil&Gas
:BUMP:
Daniel,
Did you ever get the threading figured out. I have done a lot of that. Give me a call.
Kent
