Tips for text
Here's an open discussion for text and notes in Creo and Pro-engineer.
Add tips and tricks that you know and ask questions that would be a good addition to this topic.
If you know of any previous threads that will compliment this topic please provide us the link.
GD&T
• Use parametric GD&T when you can, and try this if you want to create a custom note.
Type this as the text:
And get this as the note:
• Notice that you type @[ before the symbol and then type @] after the symbol to create a box around it.
Here is one i strayed upon recently. If you have a multi line note with a leader, you can change the position of the leader line relative to the note itself, by adding @O to the start or end of a line. Apologies if someone already covered this, it is a rather long post.
John
Superscript
25 ft@+2@#
Notice that @+ goes before the text to be superscripted, and @# goes after.
Subscript
C@-6@#H@-12@#O@-6@#
Notice that @- goes before the text to be subscripted, and @# goes after.
Hi Kevin...
The links didn't seem to work. I know what they're supposed to show... but they're not showing!
What links?
Multiple formats within single note
To edit the style of one section of a note, first click to select the entire note, then click again to select just the section you want to change. You can then RMB -> Text Style... and change size etc as required.
This works directly with separate lines within a note, but to change just one part within a line you must first separate that section by adding {1: and } around the relevant text:
{1:Large Text} Small Text
Separate Line
Then close the note editor and proceed as above.
To insert text symbol directly from the keyboard (text symbol as a font): press CTRL+A when in a Note Properties window.
To come back to standard font, press CTRL+B.
In the exemple below I typed "azertyuiop"
To round the value of a parameter called in a note, add [.X] after the parameter name, X being the number of decimals.
Hi I triedyour Tip, But It's not working in WF4
I entered text notes as
Volume Filled: &PRO_MP_VOLUME.X
I am getting same as like text, If I remove .X then it's coming volume value without units and with 3 decimal places
If you entered it exactly like you said, then you forgot about brackets. It should look like:
Volume Filled: &PRO_MP_VOLUME[.X]
Otherwise, you'll get plain text, because there is no parametr PRO_MP_VOLUME.X in model.
To see the result of a note change without closing the note window, simply click on your drawing's background when the changes are done.
It will act like a "Preview" button.
Dale_Rosema
What was the trick for putting in your own dimension?
It has something to do with @D0 or something and then you type in your own dimension.
DomenicLaritz
@OmyOwnDimension - @O overwrites the default content
Dale_Rosema
Thanks. That is what I was looking for. Just remember it's an "O" (oh) and not a zero.
If you don't want to mess with pen tables and you export PDF drawings, try assigning "thickness" to your text.
I use .012 in in/lb (SAE) drawings providing nice crisp text in the PDF export.
Also, a nice font for distinguishing 1 (one) from I (upper case i) and l (lower case L) is ISO30985FONT. It is the closest thing I found to the Creo Direct Modeling default HP font.
Anyone know how to create the Feature Control Frame B below?
http://www.kxcad.net/ugs/SDRC_I-DEAS_NX_series_Help_Library/des_ug/graphics/s8Dmgf2dobo.gif
Hi Antonius...
That's called a Composite Tolerance. from the Datum Refs tab, select the radio button for Composite Tolerance. See below. If you need help with the other stuff (diameter symbols, etc) just let me know.
Thanks!
-Brian
I found this that might help this category:
Use a $ in relations to use negative values -
Relations
All relations valid in a Creo Parametric model can be entered in a Pro/PROGRAM design.
If an expression you want to include in the RELATIONS statement contains more than 80 characters, use a backslash (\) to interrupt the current line and continue the expression on the next line.
The format can be as follows:
RELATIONS PARAMETER = COVER_SIZE/2 + LENGTH*0.75 -\
0.75*d3*d3 + THICKNESS*2 END RELATIONS
Changing the material density in a part causes the system to update the mp_density value in relations and vice versa.
Note
  • When using negative dimensions, a dollar sign ($) must precede the dimension symbol in both the input statement and the external input files. For example, use $d20 instead of d20. The dimensions will not be updated if a dollar sign does not precede the symbols.
  • If the program assigns a value to a dimension variable that is already driven by a part or subassembly relation, two error messages appear. Edit or remove the program relation and regenerate.
Also found this:
If you have a string of variables like in hole callouts, you noticed that you require spaces between the end of the variable and new text characters. This is why you see...
&THREAD_SERIES - &THREAD_CLASS
UNF - 2B
...a text string which is obviously not to any standard that we as engineers accept.
But there is a little known method to remove the requirement for the space:
{0:&THREAD_SERIES}-{1:&THREAD_CLASS} ...which returns
UNF-2B
Old school editor but this is what makes it work.
Why didn't PTC do this for the hole CALLOUT_FORMAT?
PTC, are you listening? This is what "we" call fit and finish
The extraneous spaces have always been an issue. I've been removing them for years... or else just skipping the automatic cosmetic thread notes altogether.
Dale_Rosema
I have seen before where the font size was changed within a text box (i.e. not separate text boxes).
