To change color for the complex assemblies
  • August 22, 2015
  • 10 replies
  • 5895 views
if i want to change the color for the particular assy having some 10 child parts and i want all the parts to be in the same color
normally in wildfire if select the assembly in model tree and i select the particular color in the appearance manager it will change but it is not happening in creo 2.0.i have to select all the parts in the model tree to give the same color.pls find the attachement for better understanding
may be some other options will be there,can anyone pls guide me
Dinesh
MartinHanak‌
Dinesh,
  • open an assembly
  • select color
  • select assembly node at the top of model tree
  • click MMB
That's all...
Martin Hanak
mrd10-MarbleAuthor
martin,
thanks for your reply,can you explain what is MMB,i couldn't get you
Middle Mouse Button
I have a complex assembly of released parts in windchill with part appearances defined.
I created a new assembly with this assembly in it.  I want to change the assembly/part colors to all grey and insert a "colored ay" into it to show hose routings on a drawing.  The drawing will show shaded AY.
So i can change all the colors how i want, but when i save the assembly and reopen it, it defaults back to the set part colors, which is not what i want.  Is there a config setting to use the assembly appearance colors and over ride part appearance just for this assembly?  Or a way to do it
  • open new assembly
  • assign color from appearance library to sub-assembly (select sub-assembly node in model tree)
  • save assembly
  • that's all
If the above procedure does not work, then:
MH
