To record steps live during creation of a model, an assembly or a drawing in Creo 2.0
  • September 3, 2015
  • 7 replies
  • 2887 views
Is there any facility to record steps LIVE that are taking place on the Creo 2.0 screen when the user is in the process of creating a model, an assembly or a drawing? Please revert if you find any solution. Thanks in advance.
Best regards,
Simha
Your trail file will capture every move you make within each session.
psimha1-VisitorAuthor
Hi Ron,
Thanks for your reply. Can you please let me know the steps to play the trail file?
  1. Using the standard Windows Rename command, rename the trail file before running it.(you can not rename the trail file from within Creo directly)
  2. In a Creo session, click File Manage Session ▶ Play Trail File. The Open dialog box opens.
  3. Select a trail file and then click Open to run it.
