Tutorial: Sheet Metal Conversion - two examples
  • September 8, 2018
  • 12 replies
  • 7183 views
In this tutorial, you can learn How to use Sheet Metal Conversion modelling technique in ProE or with same logic in Creo Parametric.
This video was created based on question from a comment under my video on YouTube channel. Fell free to contact me or leave a comment, or idea for another Creo tutorial.
Vladimir Palffy - www.4kside.com
Tags: #proe #creo #creotutorial #tutorial #4kside #palffy #vpalffy #vladimirpalffy
2-Explorer
September 10, 2018
Hi @VladimirPalffy
 the second method is absolutly fantastic. All in one feater... itΒ΄s around 6-8 features less than l would use.
Applaud for you...
Thanks for great tip
Good stuff, thanks for sharing it.
A method I've used that's similar to the second is to shell the solid before the conversion.  If you shell to the length of the return flanges you want, you can get consistent flange length on a more complex part where a simple extrude won't give you what you want.
HamsterNL
18-Opal
September 14, 2018
@VladimirPalffy @dgschaefer
I have a challenge for you guys πŸ™‚
We use the "start with solid, then convert to sheetmetal" method a lot, but this part in particular is giving me headaches.
Please see the picture below. The edge the red arrow is pointing to is now defined as an Edge Rip, but I want to have a Bend at that edge. But Creo keeps throwing an error when I want to change that edge to a bend.
In my mind, it should be possible...can't get it to work.
Any ideas?
Hi, thanks for your example.
This week I am out off office, but next week I will create it πŸ˜‰
Best regards Vladimir
HamsterNL
18-Opal
September 14, 2018
Thanks in advance, I'm looking forward seeing your solution πŸ™‚
P.s. The part posted is from PRO/E Wildfire 4, but we also have Creo 4.0
