Undesirable folds in geometry using swept blend.
- September 9, 2017
- 1 reply
- 1067 views
Hello
I have a swept blend for a rectangular wing made up of many airfoil sections. There is a sharp span-wise gradient close to the wingtip ( similar to a winglet design ) where creases or folds keep on occuring. I tried modifying the underlying trajectory but that only makes matters worse.
Can you please suggest an alternative to fix this problem ?
Thank you
